If you do:
figure a way to organize the parts first and take lots of pics. Label stuff as you take it off.
the intake manifold can be tough to get off, what I wound up having to do was heat the manifold with a heat gun around the joint with the cyl heads (be careful) and then use a couple of padded screwdrivers (duct tape) to carefully pry in between the manifold and the edges of the block. Be careful with this you don't want to scar the sealing surface. The intake gaskets on mine were baked on like Kryptonite.
getting the head bolts out can be difficult esp if the engine was raw water cooled, I used an electric 1/2" De Walt impact gun. Lucky I did not break any bolts.
I would up replacing the head bolts (got a set of ARP bolts) and spent a lot of time cleaning up the block deck surface, the intake sealing surfaces and the cyl head bolt holes in the block. That took the most time.
After that, the tricky parts were setting the hydraulic valve lifters and getting the distributor in right. Just take your time. These engines are stone age technology very easy to take apart and repair, if all you are doing is pulling off the manifold and heads.
the risk is the bearings can be damaged by water in the oil. I got the water out fast and my bearings are still good, no noises and same oil pressure as I had before the head gaskets blew.
