skyman2112
- Aug 7, 2015
- 74
View attachment coldstartS.mp4
View attachment HotStartS.mp4
View attachment Backflush.mp4
Hey group, my 2011 Crownline 21SS with a 6.2L 377 MAG w/cats, Bravo 1, is slow to build water pressure when engine is warmed up only. Takes over 15 seconds to exceed 1psi so it sets off the alarm and goes into gaurdian mode temporarily.
Seems like theres not enough back pressure when the engine is warmed up (thermostat open) and it starts at 0.2 psi but slowly rises to over 1 psi, which is enough to reset the alarm and continue using my boat, but super annoying waiting for the alarm to reset every time i start it when its warmed up.
When i start it cold i get 1.4-3psi (thermostat closed) immediately. See the attached videos for hot and cold starts in the water, as well as me backflushing the line that feeds the pump while the boat is on the trailer.
Already replaced everything twice, dont suggest anything simple please such as new pump housing and impeller, pressure sensor, poppet valve spring, thermostat, or inlet hose restriction, There is plenty of water flow it never runs hot.
Its been 4 years of the same problem gonna try this forum again.. Had to buy my own Rinda scan tool this boat is so touchy.
