Help please
Brian133
Hi does anyone know what type of trim awuator this is. Need to replace it boat is currently wrapped for winter cant get into it. Ty
??-I say it is hydraulic.----Look inside the boat for a motor / pump / reservoir and black plastic oil lines going through the transom.----Any other pictures of this project boat ?
Brian133
Ok thanks. Im unable to get inside of boat. Just got shrink wrapped for winter.
Are you looking at buying this boat ??-------Remove the screws on that broken cylinder and I believe you will find one oil line going to that cylinder.
bennet hydraulic, must remove the lines inside the boat before removing actuator.
system uses ATF (pure ATF, not dexron or type F)
you can get replacement parts for the actuator vs replacing the whole actuator. the seals and rear hinge are available for only a few $
never mind, you need a new cylinder. make sure to measure, there are two lenghts.
Brian133
Thanks Scott.
Brian133
Thanks Scott.
Theres no way i can use the old hydrolic lines and just remove actuator. I have pics of the engine before i had boat wrapped i have a feeling its gonna be tough to get to. Its a 2006 larson cabrio 274. No generator
