Evinrude XP-100 Block compatibility?
Hi guys i'm rebuilding a 1989 gt/xp 100 crossflow and the original block is ruined. the sleeves on 2 cylinders have nicked ports and deep gouges from the ring catching, and was wondering what replacement block can be used? the 88/90 hp block has smaller ports, but not sure about the 110/115hp motors as they have a different part # for the block as well, but of course those use the bubble back exhaust and the xp/gt is a flat back. is that the only difference? i want to make this motor correct with the correct ports and heads, not just slap on any v4 block and tune from there. and i do realize i could just put new sleeves in the original block, but really dont want the extra risk involved. thanks!
flyingscott
Pretty sure that uses the 115 block.with smaller carbs and no bubbleback.
awesome thanks! i'm re-doing a flying scott 60hp 59' nightmare generator model. will have to post in that section next lol
flyingscott
I would listen to racer on that he has probably seen more of them than I have. I always though that the 100s were flat back.
no the xp/gt 100 is a flat back 100% literally just got done taking the heads off to inspect damage. its a rather unique setup with a flat back and big-bore carbs 1 5/16'' if im not mistaken. im sure racer can chime in here but kind of an odd-ball v4 which is why i want to keep her original. thanks flying scott... i was going to ask how to get a voltage regulator for it as the original delco one is long gone. those pistons seem tight in their bores no wiggle at all!
Is the serial # on the block the same as the serial # on the swivel bracket, yes or no ?----Nothing unique other that marketing a 115 HP motor as a " fast " 100 HP model.
flyingscott
Your.Scotts have a 59 Delco voltage regulator same as a car. The generator is also a delco straight from GM cars only difference is it is also the distributor. Make sure.you flash.it.
Yes Racer both are the same. blocks original. the interesting thing, and why i called it an "odd ball" is the carbs are not jetted the same as a pre-1986 115hp (as thats a flat back, figured its what the gt100 is modeled after). the gt100 uses 60c high speeds, and the 115 used 67's. also, no extensions on the gt-100 air silencer, but all the other models, including the 115 have airbox extensions. ill grab a used 115 block and just hope ports are the same i guess!
What is the model # of your XP / GT motor ??------What size are the intake ports on your GT / XP model ?
