I need a small in-dash tachometer
BWR1953
I've been seriously thrashing the web for a 2" diameter tach which can mount in my dash and work with a 2-stroke motor. So far, no joy. I've found a few automotive tachs which would fit, but can't handle 2-stroke engines.
There is very limited space on the dash for the tach. I suppose I could mount one on top, a la '69 GTO, but that would be inappropriate. :lol:
Looking for a little help! :joyous:
BWR1953
Have a look at tiny tach
I already have a clone of one of those. It's pretty flaky. Switches configurations right in the middle of running a test. :rolleyes:
And I'm looking for something with a standard permanent mount that can I wire into my harness. Those temp tachs don't fit the bill. :grumpy:
The suzuki gauge needs the ECM on the motor to drive it
you could use the 2" faria gauge, use a mag pickup, like used on a diesel, and install 4 screws in your flywheel. That would give you 4 pulses per revolution
BWR1953
Couls also have sam am I sketch up a signal conversion schematic to take the ignition pulses from the OB and convert to the sinking signal to trigger the tach
BWR1953
I found a video last night where a guy built a converter to allow using a standard automotive tach. I'll be looking into that for sure.
sam am I
Hold the phone!!
That "converter" is just a signal conditioner...........
AND,
*Tohatsu 18HP 2 stroke stator is 4 pole = 2 pulses/rev (recall electrical pulses per revolution are equal to 1/2 the number of alternator poles.)
AND,
A 4 stroke, 4 cylinder engine puts out 2 pulses/rev!!! Note in the video he's set his 4 stroke tach to, "4 cyl". (For 4 stroke engine.....1 cyl = 1 pulse/2 rev, 2 cyl = 1 pulse/rev, 4 cyl = 2 pulse/rev, 6 cyl = 3 pulse/rev, 8 cyl = 4 pulse/rev, 10 cyl = 6 pulse/rev)
Soooooooo......in English?
A guy (him) can use/get away with using a 4 stroke tach set to "4" on a(his) 2 stroke Tohatsu because its (his) stator puts out 2 pulses/rev just like a 4 cylinder 4 stroke....LUCKYYYYY!!
He therefor is just "conditioning" the signal and really doesn't even need that "converter".......
You have a 12 pole stator = 6 pulse/rev.............You'd need a 4 stroke tach that had a "10" cylinder setting (10 cyl = 6 pulse/rev)
*http://www.projectk.co.jp/marine/pdf/faria_tacho.pdf (See page 3)
or use a mag-pickup that normally reads flywheel teeth on a diesel. and have mounted so it reads 4 bolts in the flywheel to give 4 pulses per revolution. that will mean a 8 cylinder 4-stroke tach would work for the application
or the tach could be pulled apart and the output of the D/A converter adjusted to read properly since the small 2" tachs do not have a cylinder switch setting
BWR1953
Hold the phone!!
AND,
AND,
Ah, jeez. If figures that it can't be simple. :rolleyes:
Okay, thanks. :)
Now I'm gonna go work on my truck. :lol:
sam am I
Correction to #14, 10 cyl = 5 pulses/rev NOT 6 pulses/rev
