BlackoutBill21
Thread starter- Joined
- Dec 10, 2016
- 181
I have a 1982 35Hp Evinrude. E35elcnd but the top part of the carb is toast..
I have a 25hp carb from a 1971 25hp motor.
the top of the carbs are IDENTICAL. With the exception of no Venturi through the throat. And the throttle linkage is a little different.
the high speed jet in the 25 bowL is stamped 72.
the jet from the original carb bowl is stamped 59d.
i was going to swap the jets but the 59d (original to the 35 carb) looks like it has a smaller opening then the 25 carb jet stamped 72.
can I use the 25 carb with the 35 jet and get 35hp out of my motor?
