How to fix scratches and dents on aluminium channel on gunwale
Starcrafty
Hi everyone, new starcraft owner. Bought a 1979 16'SS and hauled all the way from MI to TX. It was going so well for couple of months but today we went to a lake we were unfamiliar with and the dock was terrible without any padding.
I had to tie the boat to the dock to get the trailer but wind gusts banged the gunwale of the boat pretty bad in 5 mins and the aluminium channel got dinged and scratched and the rubber insert came out partially. I pushed the rubber insert with flathead screwdriver inside but it's still scratched up. Is there a way to get both the channel and rubber insert look good again?
feel terrible. Should have docked on the other side so boat wouldn't have banged against the dock.
welcome aboard
you can spend lots of time with a small sheet metal flange tool to get the channel straightened back out, and then re-paint it
the rubber can be bought new
dingbat
Finger nail polish remover or Penetrol on a clean rag will clean the plastic right up. Make it look like new
Starcrafty
welcome aboard
Thanks for the tip on flange tool for the bent part, but as I understand from reading other threads, the channel is anodised and the scarring left dents, I was hoping to see if I can restore to the original aluminium and not paint it. Is that possible ?
no, you will see the crazing in the anodizing if it was anodized. most likely it was just a 5000 series extrusion. in that case, scotchbright pad
dingbat
Thanks for the tip on flange tool for the bent part, but as I understand from reading other threads, the channel is anodised and the scarring left dents, I was hoping to see if I can restore to the original aluminum and not paint it. Is that possible ?
The only way to repair an anodized piece is to have the part anodized again.
Could clean up the damaged area and apply a clear coat finish of some sort but you would have a color difference to contend with
