Wont start when cold only
Zack19919853
Zack, The starting fluid that I purchased has a cylinder lubrication in it, so I think it would be just about the same as the gas with oil in it for the very small amount that I was using. I would not use it without the lubrication in it. Anyway, I think I solved the problem now. Thanks for all of your input. I appreciate it! Also when it does flood (rare occasion in the past) I remove the gas line from the motor as well and pull the cord a few times and gas comes out of the connection at the motor pretty much, then remove the plugs and pull the cord some more like you suggested.
Cool man that’s great what did you find out?
iggyw1
Ensign
I found that the air/gas adjustment was off. It was only 1-1/8 turns out. My manual calls for an initial starting point on that screw at 2-1/2 turns out, so that's where I put it. It started on the first pull this morning and again this evening, about 10 hours later, it started on the first pull. (Cold motor). It is idling really nice, but I will tweak the screw on the lake (hopefully tomorrow) when I am trolling so I get the correct perfect setting on that screw. I am very happy now!!
Zack19919853
Nice man glad you go it going!!
