Speedometer
PreachRick
I just purchased a new (to me) boat. It is a 1983 Mercedes walk through. The speedometer does not work. Does a boat speedometer work off of the motor or off of something else. The Motor is a Mercury Marine Serial # 6365879
GA_Boater
Something else. Either a pitot speedo pickup on the stern or built into the lower unit and some speedos use GPS for speed.
My project boat will have a GPS speedometer.------Just hook up 12 volts and away you go.-----Mine wiil be accurate from 0 to 80 MPH.
Kingmt01
Posting a serial number usually doesn't help much. It's kind of like posting your VIN number as public information. However there is digits in a vin that can be useful. Also vin numbers are usually registered to you while serial numbers you have to keep track of yourself.
GA_Boater
What in the world are you talking about? This has nothing to do with speedos.
