nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,109
getting close to firing up my 4.3l. I thought I had everything I needed to start out of the boat (wiring harness and gauges from old boat) but don't have the shifter with me. So plan b was to jump the pins on the motor harness. Double checking the pins I got some odd resistance readings. There was some continuity between purple and most of the other wires: about 1.5k ohms, including purple and ground, and continuity between purple and gray. Also 7 ohms across the coil terminals. Chased it down to the connector on the TB module. With it disconnected, there's no continuity between ground and any other wires except gray, which is still 7 ohms. So is this expected behavior or did I miswire something?
