Pulling to the right
Jdevon_14
Just got my boat up in running. It's a 73 sport craft with a 73 merc 850 on it. It's pulling hard to the right and adjusting the torque tab to right didn't help at all.
Jdevon_14
Doesn't have power trim but i'm going to adjust the trim pin up and see if that helps
The second hole from the transom is the standard spot for the trim pin. You can raise it up a hole and see how she handles. If it is too high, she can ventilate in the turns.
Jdevon_14
It was on the 3rd hole from the transom and was still pulling hard to the right
Did you turn the trim tab (anode) the correct way? Also, Merc makes 3 different anodes (trim tabs). Large fin, small fin and no fin. A large fin gives the best counter torque, but only works with a standard prop. Props with more rake than std., need the small fin anode.
