Can you put brakes on this axle?
Nattybluewater
Dexter torsion 3500lb. I am selling them bc they don't fit my trailer and someone said yes and others have said no. Thanks.
GA_Boater
Welcome aboard.
Yes, the square flange with 4 holes is for mounting brakes. The spider hub has to go, but any add-a-brake kit would have a brake drum or disc brake hub.
gm280
Probably most any axle setup could be modified to put brakes on. But the cost involved with some would be more then buying the right brake axle.
Ayuh,..... Welcome Aboard,...... The 4 bolt flange is there, so Yes, go for it,.....
