Nothing happen when ignition is turned on
medic55
I own a 1997 Fisher freedom 200 pontoon boat with a 60 hp merc out board. when I turn the ignition on nothing happens.there is power to the dash switches because my lights and fish finder will come on I have no power to my gauges also my trim will not work any help will be greatly appreciated ...Thanks
Ayuh,..... Welcome Aboard,...... Clean to shiny metal Clean, the battery cables,.....
Both ends of both cables,.....
medic55
Battery terminals clean,( nothing happening ) I have bought a new ignition switch and kill switch.
roscoe
did you check the main fuse on the side of the motor?
The kill switch only grounds out the ignition, it has nothing to do with the other motor functions, gauges, starter, etc.
medic55
I am new to boating and when I bought the boat I did not get any manuals. and the person I bought it from is not around to ask question. Now to your question I took the cowling off to look at the motor, low and be hold I see a fuse holder checked it and yes the fuse was blown. replaced the fuse and everything works....I WILL be ordering manuals for the motor
Apollo Dynasty
I have a 1987 Apollo Dynasty and it started ok then started backfiring through the carburetor. I put a fuel pump changed the points, condenser, plugs, and wires. I went to start it again and it started clicking around the starter. I changed solenoid and now it won’t do anything. Any ideas? TIA
JASinIL2006
Hi, and welcome to iboats. You picked the right place to get help for your boat. Unfortunately, you're going about it in the wrong way; tagging your question onto an existing topic is known as hijacking, and it's poor etiquette. You're MUCH more likely to get help, and less likely to derail this existing topic, by starting your own thread. (If you haven't already, be sure read and follow the forum rules at https://forums.iboats.com/forum/forum-rules-and-guidelines/407734-attention-forum-rules-attention.)
Again, welcome!
