Boat won't shut off
Mbalafas
Ok so here goes. Few weeks ago I was working on the boat and had to fix a wire connection out of the alternator. The wire in question had a rubber block on it. Well llong story short the rubber block is gone. Up until the other day boat would shut off fine, however now all of a sudden it only shutd off when I oull the top wire out of the distributor. I've been looking and most sources point to a diode. Anyone know whats going on?
the engine is the aq125a
alldodge
Agree has to be back feeding, but I'm not seeing a diode in the schematic
alldodge
So new alternator?
Don't know, have not done enough testing but don't think so. The coil only has one wire coming from the key to the + side of the coil. The + side of the coil should only have one wire on it, is this true?
If there is only one wire then need to check the wiring on the key switch
