Sinking boat and life jacket storage
sublauxation
Haven't been around much lately but wanted to post this one up because it's something I never would have thought about and on bigger water it would have been serious. I'll try keeping it short.
We were sitting around the fire at the lake Sunday when I noticed a boat about 40 feet from shore. It's a small, shallow lake with a sand bottom and the water is pretty low. I didn't think much of it but about 10 minutes later I noticed the 2 occupants bailing water.
I hopped in my boat and motored over to see what was up, it was an older couple in an aluminum boat. He said they initially noticed water on the floor, thought they spilled the minnow bucket but quickly realized it was more serious. They were beached, taking on water and with both of them bailing weren't keeping up.
I initially assumed some tubing for the live well probably broke so I used a couple plugs I keep on my boat to plug both the back inlet and outlet. I also hooked up the live well pump from my boat that is set up to use as an emergency bilge, then jumped in to help bail. With both pumps working and 2 bailing we weren't keeping up. There was about 3-4 inches of water above the floor which made it hard to get a full bucket of water so we tried to open the floor locker to make it easier.
Even with 2 of us standing on it there was so much pressure on that floor locker that we couldn't spin the latch to open it. Turns out their life jackets were in that hatch (neither could swim) and they had absolutely no way of getting them out. The woman said that's even where Tracker recommended storing them!
At that point I was reluctant to tow them because I assumed that a weld had split and pulling them out would be a mistake but another guy came along and they consented to being towed to the launch. I stayed aboard bailing like crazy until we were able to get it on the trailer. (Being in Wisconsin, while this was happening another neighbor came out and brought us mixed drinks!)
Turns out the front live well thru hull fitting sheared off leaving a 1 1/8 round hole in the hull.
All ended well but had that been bigger water, and they been further from the launch it could have gotten serious quickly. Nothing like having your life jackets stuck under the floor, pushing up on the access door making it impossible to open and get them as your boat is going down!
When boating I keep mine on the back of my seats, easy access an they provide a bit more cushion!
plastic thru hulls have no business on a boat.
sublauxation
Agree completely, my pick up is metal with a metal shut off, meant for beer and oil tanks! My floor locker hatch is open grates so I can see the bottom of the hull.
GA_Boater
Good you were able to help them, Sub. Even a PBR would have been welcome afterwards.
The lady should reread the owners manual. I'm sure Tracker recommends using PFDs and it's kinda difficult to use them inside a locker. Storage is one thing and having PFDs ready for use is another thing.
sublauxation
Yeah, pretty sure the manual meant "on shore" storage but lots of people don't stop to think about that "on shore" part!
harringtondav
Kinda related....I've know a few that keep their hand held fire extinguisher in the engine bay. One had their boat catch fire and was a total loss. Why? The extinguisher was in the engine bay where the fire started. Totally worthless. Ours is under a bow cushion. PFDs are under the bench cushions.
sublauxation
That's another good one! Mine is under the tip of the bow in the anchor storage area. Death via boating is low on the list of ways I want to die so I think I've done a good job with redundancy but it is easy to miss the obvious some times!
dingbat
Captain Caveman
sublauxation - that was great of you to help them out. However, there is the side of me that shakes my head and the fools out on boats. If you can not swim, or are not a strong swimmer, you should wear a life jacket 100% of the time. One could argue that everyone should wear them 100% of the time. These folks don't seem to be the brightest people in the world.
sublauxation
I see the potential weakness issue and I do remember reading this before putting mine together. The brewing world is full of nice stainless steel products including ball valves with the correct threads.
dingbat
Except stainless is susceptible to crevice corrosion and should not be used below the water line.
Brass, copper and plastic are also not to be used.
Only bronze and marelon are approved for below water line use.
And marelon is not allowed in the engine room
76SeaRay
Since I am doing a full restoration, I am replacing every thru hull (7 of them) with stainless getting rid of the original plastic ones and using all new hoses.
I am also thinking about life jacket storage in the ceiling of my hardtop (easy to get to) but will be getting two of the inflatable type for myself and one guest to wear on the boat. Those are not bulky and give better freedom of movement.. May get the auto inflation ones that activate when you hit the water..
Fire extinguishers will go one starboard side and one port side, amidships for both.. Maybe one in the cabin for sleeping at night... A single fire extinguisher can empty quite quickly... Thinking a smoke detector or two might also be in order for nights on the boat now that we are talking fire safety..
