Which Lightweight Oil
oba97
At the risk of sounding like an idiot... what lightweight oil is best for lubricating my steering link rod pivot points?
ahicks
There may be a better solution, but I would use motor oil. The same stuff you use when changing the oil. Or possibly lower unit lube (80-90wt). IMHO, what you use is less important than how often you use it. Just don't use WD-40.
JimS123
When I bought my first jetski (a SeaDoo) all of their lube points were to be done with "Bombardier Lube", in a spray can. I always use OEM stuff per the owner's manual.
Nevertheless, that product has become my goto for everything now. It's just that good.
Even though I now own a Yamaha I still use Bombardier Lube.
oba97
My mercury owners manual just says lightweight oil. I guess I’m not exactly sure what that is? Is the oil you use for pneumatic nailers considered lightweight oil?
Sea Rider
Always use Hydraulic red fluid which is very thin to lubricate all knids of mechanisms specially the ones in which thick oil won't reach or lubricate properly. Try it...
Happy Boating
JimS123
5W motor oil, sewing machine oil, 3-in-one oil, gun oil are all light weight oils. You probably have one of those around the house already.
Pneumatic tool oil has quite specific properties, just like compressor oil, transmission fluid, etc.
oba97
Thanks everyone for the input. I ended up picking up some 3 in 1 oil.
Grub54891
I've found over the years, 3-1 oil varnishes up over time. I'm mostly using gun oil or sewing machine oil on stuff like that nowadays. However I haven't tried hydraulic oil.
JimS123
Hydraulic oil is intended for high pressure applications, not really for "lubrication", per se'. Not that it doesn't lubricate, but it would not be my first choice unless I had a can laying around and it was free.
My guns function awesomely with Hoppes Gun Oil, and at $1.49 a can how can you go wrong. (now, if you have a US M1 Garand, the oem US Mil Spec oil would be even better I would imagine.....but that's not readily available)
Grub54891
I ran out of gun oil a couple years ago, the local hardware and big box stores only had it in spray cans now. Messy. I went to Wally world and looked in the sewing department, saw sewing machine oil, it stated on the bottle that was for Guns also. And cheaper than regular gun oil,
dingbat
I use white lithium grease (spray) or T-9 Boeshield for those types of applications.
Use both to lubricate link pins and ball sockets on 3 pt. hitches.
Penetrates and adheres very well. Minimal washout. Leaves a water proof protective layer.
Faztbullet
I use Maxima Chain wax lube....best stuff I have ever found for cables and chains
Jim...I always wanted a "tanker" model ..but love my mausers
JimS123
As do I. When CAI was selling them for $39 with free shipping I was buying one a month. The u-fix-ums at $16.95 were even a better bargain. The performance is real good, second only to any USA made item. I doubt many tankers actually survived. If you find one it would probably be a home made variant.
