2013 etec 60hp prime oil
ready4itall
Got a used etec 60hp for a good price from a private seller. He bought it from a dealer and didnt mount it because his project fell thru. It was still in its packaged state. He gave me the diagnostics form, looked good.
so i brought it home and im reading the manual that if the outboard was oil was emptied, when i refilled it that i need to prime the oil?
i took some pictures of the diagnostic and oil reservoir.. It looks empty.
so my question is, could i get away with just re-adding xd100 (its been tuned for it) and call it good? Or some other get around procedure?
or must i do what ive been finding online and bring it in to a dealer to hook up EMM and prime it?
one thing that caught my attention was, on the diagnostic, the outboard was winterized at 112 hours pf total 119 hours. So cpuld it be empty just cause of transportation? And i could just add oil in and start up?
Best take it to an authorized dealer.-----Mistakes / assumptions could be expensive.
I believe a shop can put the oil pump through it's paces without running the motor itself.----They make sure that it is working and all the air is out of the system.---Then you can start the motor.
Crosbyman
To keep yourself up to date on all ETEC specific matters take a peek at the ETEC user board at
https://www.etecownersgroup.com/?forum=136482
you may be able to prime the oil distribution my confirming with the dealer if a simple winterize will do it . ETEC can actually run with no oil (in safe mode) while you prime the system.
It may be as simple as filling the tank with xd-100 (best oil) and doing a self winterize to circulate extra oil in the engine.
My own 75HP 2005 ETEC has been a great engine.. overall trouble free after they did a software/hardware update on a chronic NO OIL issue code 38. starts on a dime purrs like a kitten, sip gas and oil, no smell and goes like he.... :)
Crosbyman
btw… I never seen a 60 up close but… the oil tank pictures seems a bit weird with that white stuff all around ??
is it the way it is built or did somebody try to seal the tank middle seam…. ETEC oil tanks have leaked because of bad seams in the earlier models… like mine (2005) which cracked in the seam after a really bad run in 3-4 foot chops
my tank was replaced on my 7 year extended warranty your model year should not have this issue but ask around or check the tank . You will know soon enough after filling it :eek: see link read and leak
https://www.etecownersgroup.com/sea...owas=threads&btnSearch=Search&action=doSearch
ready4itall
I'll take acloser look at it tomorrow after work and get some better pics.
