85 Hp Force outboard wiring question
Status
Not open for further replies.
Pells
i have a 1984 -- 85HP Force. I am new to boats so please help. The previous owner has disconnected a few wires. first off they connected the two blue wires from the stator together. Next the pairs of yellow and blue go back to the corresponding cdi units? there is 1 pair not connected to the cdi unit the wires are disconnected and taped off. The reason I started to look at this is because the battery is not charging. The stator and rectifier seem to check ok with an ohm meter as much as I could test by other threads I have looked at and in the manual. Any help appreciated. Thanks Chris
The Force power
Here is a wiring diagram so you can make sure everything is connected correctly.
https://forums.iboats.com/forum/eng...339-1985-force-85-hp-no-spark-w-new-cd-module
The only wire that should be capped off is the red wire from the #3 CDI module. The orange or red wire can be used to fire #3 cylinder but usually the orange is used and the red capped. Id assume the blue yellow pair need to be connected.
Hi Dunbarltd,
Pells has two identical questions going in Forum regarding this.
Hi Pells,
Don't get us all confused, don't ask the same question in different topics
Status
