Texasmark
Thread starter- Joined
- Dec 20, 2005
- 15,059
I have a new to me, 2002, 115 HP, 2 stroke Merc. 4 cyl 2+2 engine. Playing around with it I've been learning how it works and what I could do to make it better. I decided to put in new fuel pump and accelerator kits, noting that the old diaphragms were much stiffer than in the new OEM kits so the new ones should pump better. I set the injector gap to 0.20 rather than 0.30 as I wanted the bottom two to kick in earlier than the Serv. Manual setting specified.
I don't run long periods of time at WOT. Mostly in the lower rpm ranges and a lot in the area where I'm running on just the top 2 so plug fouling is a problem, especially the lower 2 (yes the OEM oil injector is working fine) and I run 91 octane regular gasoline with the engine being rated for 87.....I figure that's one reason for the 8 heat range in the recommended plug.
I got a tip from a guy on a tractor forum that used Iridium and premium fuel in his lawn mowers and thought I would give it a try. Results were stellar. Moving on, I decided to get a set for my 2+2, and I was already using 91 fuel. Went to the NGK plug catalog, down around page 268 (recalling) I found Iridium plugs, cross referenced my OEM Service Manual recommended plugs for dimensions and heat range (with a couple of changes listed below), gapped them out to the 10 mm required setting (0.040 in.) like my recommended plugs, and WOW, what a difference in performance.
When putting around, I tilt the engine up above level a few degrees which (per Merc.) keeps fuel from puddling in the spark plug area, helping to reduce fouling....yes it does make a difference. I also upped the temp 2 heat ranges....went from an 8 to a 6 (NGK increases heat with decreasing numbers) figuring I could get hotter as an aid to burn off contaminants without having to worry about pre-ignition or excessive combustion temperatures.
Idle is so smooth that I could put a full glass of water on the engine and not spill a drop (waves permitting....grin). Starts, even while sitting for awhile are instant.
If it suits you, might be something to think about.......just be very careful any time you regap an Iridium....the tip is very small and easily broken in the process and you will find recommendations to not regap for that reason...but with a wire gapping tool and some care, no biggie to regap which I had to do as they were at 0.030 and my engine uses .040. Thought about using them at the issued gap but that is down the road since these are already regapped.
