window tint question
griffin2
I have a 76 Silverton and I would like to tint the cabin windows. Can anyone recommend what method I could use? Window tint film? etc.<br /><br />Thanks in advance!
Pan-one
Re: window tint question
I assume the same you would a car.<br />Buy a roll of film from local auto store. You need to mix a soap/water in a spray bottel. You also need a "squegge"? Wet window with soap and water solution. Peal backing off of the tint. Spray backing with solution. Place on glass, trim with razer knife. Use squegge to get all bubbles out. Trim again, and place some clear nail polish if needed on any corners that are not sticking. If you have any air bubbles pop with a needle and use the old ladies hair drier. In cold temp it takes a while to stick.
