highpowerdad
- Feb 5, 2020
- 108
Boat is a 2005 fourwinns 190 horizon with a Volvo Penta 5.0GXI and SX drive 1.6 ratio. Entire Stern drive was replaced 1.5 years ago with a rebuilt unit, it has worked well up until recently
Hi all, Well, I thought I would be out on the lake doing some prop testing and enjoying the nice Fl weather, but, instead, after idling out down the canal, the boat wouldn’t go back into drive, or reverse, nothing…I had this happen once before, but it “fixed” itself and its been a while (I thought it was actually the neutral switch in the controller but I guess I was just hopeful). So, basically, I have what seems like an intermittent problem with shifting into gear, had a neighbor tow us back to the lift on the canal. This is what I did try to see what is going on:
- Took the cover off the drive and checked the function of the shift cable. Shifter moves up and down with the throttle lever, the center bolt was loose, I don’t know if it is supposed to be, but I snugged it down
- Removed throttle cable from shifter, ie took out cotter pin so I could move the shifter manually.
- Started motor, manually moved shifter at back of stern drive clockwise and counterclockwise, turns a little more than 1/8 turn each way…got nothing. I did notice that at some point in the rotation, the shaft pops out an 1/8 of an inch or so, I assume this is when it is supposed to engage the gear?
- Checked gear oil, it was perfect, clean and at the right level…it was just serviced a couple of months ago…
