JimS123
- Jul 27, 2007
- 8,335
How easy should this thing start, and where do I set the lean/rich knob? all the way open?.
Oh and how do I pop the flywheel off if it has no spark? like a Briggs and Stratton with a flywheel knocker?
If you got good spark and compression, and you have fresh gas to the carb, it should start in 2 or 3 pulls.
Put the gearshift in "neutral". Take the knob off and turn the needle in all the way, and then open it about 1 1/2 turns. When it starts adjust the needle so it runs smooth and then put the knob back on, positioned in the middle of the range.
I would guess that the coils in that era motor would still be good, but if not a gear puller will easily remove the flywheel.
