trashcanslam
Thread starter- Joined
- Nov 14, 2019
- 38
UPDATE: the problem was fixed by replacing the spark plugs!!! Many thanks to everyone for your help and insight.
A new problem occurred which involves surging and dying after running in WOT after about 60 seconds. However, i pumped the primer bulb manually and the problem subsided. Repeated this until I got back to the boat ramp. I suspect either the fuel pump purchased off Amazon is bunk, or the fuel hose I used is too thick and long/bent to deliver fuel properly. I am planning or replacing it with a vacuum hose. Does anyone have any insight as to whether I am on the right track here?
Thank you.
Thank you.
