Cant bring myself too take boat too landfill or fix it ?????
alan ber
Owing 22 years ,
SRV 21 ( 21 ft ) Sea Ray - Fisherman
walk around small cuddy
IO
cuddy , storage, two can lay out , get out of rain / sun , head under seat
Original power was the 4 cylinder Mercruiser - , 188 HP
I am no speed demon , for my needs pushed boat fine , 35 mph ,
HISTORY
Sea Ray called this boat Fisherman , changed name too Laguna ,
Early Lagunas walk around / cuddy , IO' , after a few years Lagunas had OB
Lagunas went center consoles , OB'S were they sit today
On my boat Original engine was done , Sitting years at home
Purchased a 31 ft luxury power cruiser , Twin gas guzzler feed me engines ,
If I did not have the big boat would have fixed the sea ray ,
Got the bug too get my old boat back on the water , fishing , trailering ,
Found a almost new 3.7 Mercuiser with 17 hours , NEW OLD INVENTORY ,
Manifold & Riser , new , engine was sitting in storage ,
3.7 has 165 HP
original engine had 185
Felt it was the fastest way too get boat back on water
Pulling old engine discovered the fiberglass movement at the transom , Stripped engine room
Cut transom outer skin , transom wood was crumbling ,
On this boat floor covers stringers .
Wood in fuel tank cavity trashed ,
Can feel foam , wet
wood motor mount , trash
Floor has too be cut out , too gain access too bones
LOT OF WORK . Never doing transom or fiberglass work ,
Shop too redo ? Costly for a boat not worth more then 5 thousand .
Recently saw same boat on POP Yachts , had twin 4 cylinder IO's 25 feet , tower , out riggers ,
advertised as a fishing machine , $ 12 thousand
Last week I saw a 21 ft Laguna same exact boat with OB , 1995 , $ 5500.
FEW WEEKS AGO STIPPED everything off boat , down the rails , wiring , WAS GOING TOO TAKE TOO LANDFILL. Engine , trailer , parts would bring more then the value
PROBLEM I HAVE , CANT BRING MYSELF TOO TRASH BOAT ,
Newer styled boats like Robalo's , Prolines, Cobia's are set up sweet , no wood
Early 2000's selling 12 - 15 grand , except used is used , Engines are costly ,
I love the styling of early Grady Whites , My boat is similar
Finding a LEGIT SHOP ? quality work , it could cost 5- 7 thousand ,
IN THERY with almost new engine , ALMOST A NEW BOAT , except Alpha 1 old, seats worn , cabin cushions old, smelly , time too redo , bimini has wholes ,
REALLY HAVE TOO REDO EVERYTHING , Only thing that looks good is hull
FOR 10 THOUSAND , were are you going too find a new boat ??
Babbling , sorry , My situation not uncommon , Like a car , repairs verses newer ,
Nobody wants those car payments ,
alldodge
Other then if a boat is a rare type that others want, a boat is only worth what you place on it. Some will put more then twice what its worth only because they like the boat (I did that). No one can answer the question for you
mickyryan
I have way more in mine then its worth but i love the boat so yeah .. if i wanted a different boat id still not get rid of mine:)
