boat paint
eaglelove76
hi<br />i have a 1969 power cat and has yuck mustard color and i m wanting to go with a red or blue and back to white on bottom hull but i need to know what type of paint to get and do i need to prep the boat as i would on a car <br />thanks <br /><br />roy
Mod2
Re: boat paint
Moving to Boat Restoration and Building.
dakk1
Re: boat paint
I painted my boat with Interlux's Brightside Polyurethane over 2 years ago and have been very satisfied. It is a 1 part polyurethane. Some would prefer a harder finish such as a 2 part paint but for a boat that doesn't stay in the water I'm happy with the 1 part paint. Advantage is ease of application. Yes, you basically prep it like a car. Here's a link.<br /><br /> http://www.yachtpaint.com/usa/
eaglelove76
Re: boat paint
thanks dakk1<br />i went to a paint place yesterday and they wanted 400.00 for a gl. of paint and hardner i about jumped out of my shoes so i thought i would get on here and see what others use before i start spending $$ its to hot to paint now id reather be fishing..<br />roy
D
DJ
Guest
Re: boat paint
I've always used what dakk1 used, with great results. Pettit makes a similar product.
Re: boat paint
I go to NAPA,+ get MSU brand paint..... I've had Great Luck with it,.. Both above,+ Below the waterline.........<br /><br />It runs about $100.00 a Gallon......
bigboy
Re: boat paint
It would help eaglelove to post what kind off paint you used and a picture off te result. That would be very cool for everybody. Because your eyes say whats the best...
garrett61
Re: boat paint
whats the best paint to apply by brush or roller topside that wont show many streaks/ brush marks?
fishingdan
Re: boat paint
Interlux Perfection is designed for roll and tip. It is a 2-part poly urthane that is very good. This paint is basically Awlgrip with brushing additives added to it. The downside is that it is very expensive. Good color selection.<br /><br />Interlux bright sides is a one part paint that is a little softer than a 2-part paint, but will also give good results. Good color selection.<br /><br />If you want a good water based product, you can go with System Three's 2-part polyurethane. It too is designed for roll and tip, but it has limited color selection and results in a semi-gloss finish unless you apply a clear coat.
Jeepnn
Re: boat paint
You are not alone I am restoring a 60's Starcraft and am haveing the same questions so Thanks everyone.<br /><br />Mike M.
