Jmesser1980
Thread starter- Joined
- Jul 29, 2019
- 2
Hello Everyone,
I'm not the best at wiring and had a question for you fine folks.
My dad has a center console boat that he puts around on, the Bilge pump/ float switch started acting up this year. When we put it away last year all worked fine.
I believe the float switch is bad and needs to be replaced, the problem I am seeing and what I do not understand is when the power switch is turned on and I turn on the Bilge Pump to manually pump the water the pump does not turn on unless the float switch is turned off, all the accessories (Lights, Horn etc.) also do not work unless the float switch is turned off.
I'm not the best with wiring but to me I would think the float switch and bilge would be separate from all of the other accessories.
I'm pretty sure it is a bad float switch but am now starting to wonder if the guys at Bass Pro where my dad bought the boat and had the float switch installed did something in-correct when wiring the float switch in.
There is a Red wire that runs from the battery with an in-line fuse to the float switch then there is 2 wires running out of the float switch one goes to the bilge pump, not sure where the other goes to.
Any suggestions is greatly appreciated.
