peterskeeter
Thread starter- Joined
- Aug 24, 2008
- 86
Looking to add a NMEA 2000 fuel flow sensor to a Garmin 54cv. Is there a better option than using Garmin's GFS 10 sensor? It will only read at minimum 2 gph I'm understanding. Are Lowrance NMEA 2000 sensor's compatible? Also, if this is the only NMEA 2000 sensor on the unit, will you need to use the entire starter kit? Sorry if its a stupid question, just seems the starter kits allow you to build a network of sensors. I just need fuel flow instrumentation for an older carbureted 2 stroke 150hp engine
