FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
i have a older version of Bennett trim tabs with the 2 rocker switch control with no indicator. do I have to replace the whole system to be able to tell the position of the tabs. Can it be added in.?
I added just the the indicator but my trim tabs had the sensor wires already.
If you don't have the sensor wires you will need the complete kit that includes the sensor components for the hydraulic actuators.
I have the older version Bennett trim tabs on my boat. I never can remember where they are. I have seen kits to add on to make them show their location but I was wondering if it would be better to replace the whole system with a newer version that does that.any body else done this.?
call bennett and talk to their customer service. probably the best customer service of any marine company on the globe is bennett marine.
they will let you know what you options are, and what pricing is.
however if you get in the habit of raising them when you slow down, and adjusting when you throttle up, you get a feel for exactly where the tabs are and where your motor trim is without ever looking at a gauge or indicator.
Indicators where on the short list of mods but I decided to scrap the project given the usefulness of the information.
Tabs don't do much for me beyond leveling the boat underway. Anything more than one thousand-one, one thousand-two, one thousand-three from the neutral (plane) makes the boat very squirrelly.
Side to side leveling varies on wind and tide. Done totally by feel.
If you could scale the output of the sensor to match usage I could see it being helpful, but spending the time and effort to see if the tabs are 1 or 2 bars off plane on a scale of 0-10 seems futile to me
Ayuh,..... I built my own,...... A piece of 5/32ths" ssteel tig rod attached to the plate on 1 end, up through a bracket at the top of the transom, 'n a couple nuts threaded onto the top,....
If I glance back, 'n see the nuts, the tabs are up, 'n I can hammer the throttle,.....
I installed the TPI2000 indicator on mine because I found one cheap.
My actuators had the sensors already so it was an easy install and I didn't need anything else.
