Wiring DSC VHF to chart plotter
col421
Hey there folks.
I'm trying to wire my VHF to my chart plotter so that my radio can get GPS data for a DSC distress call and sending my location to friends thru DSC. Also would like to have any DSC positions reported to me on the vhf show up on my chart plotter as an icon. It has the capability if wired correctly but the wiring diagrams don't seem to be talking the same language. The radio has positive and negatives identified but the plotter only has inputs or outputs. See attached wiring diagrams for the radio and chart plotter. Also there is a bare ground(shield) wire on both cables. Not sure if i run both of those to the neg bus bar or connect them or forget about them. Any help on which wires go were would be appreciated.
GA_Boater
Welcome aboard.
It helps to have some basic info. What brand/model of plotter and VHF?
col421
I guess I left out the models.. the radio is Uniden UM 385 and the plotter is a Lowrance elite 7ti
KC8QVO
For what it is worth, I have a Standard Horizon GX-2200 with AIS and a Garmin 820xs plotter. I used to live near a shipping canal. The AIS receiver in the VHF radio did a nice job plotting all the barges going through the channel. They showed up as icons on the plotter screen. Clicking on the icons you could see information about the barge/company.
AIS, if you know anything about Ham radio, is like the equivalent of APRS. However, you need a special transmitter. That is not part of any of the VHF radios that have AIS receivers built in, that I am aware of. There are 2 levels of AIS transmitters - a low power one and a higher power one (they are both relatively low power... only a few watts). They are very pricey for what they are.
I am not familiar with the DSC functionality you are referring to, though my radio has that also (I have never registered anything with it so I don't have the radio set up to do it - if you register and need to change the ID you have to send the radio to the manufacturer to reprogram so I've never messed with it). Others may be able to guide you through that better.
I'll see if I can dig up a screen shot of the AIS. It is pretty slick. If you had 6 people out fishing you could see everyone on the screen - so long as their AIS signal was receivable at your boat.
dingbat
First off , did you register and get an MMI number for DSC?
The diagrams are talking the same language, just a different Dialect ;)
NMEA Out to RX, NMEA IN to TX
The + and - are different channels for additional I/O
For the wiring, brown to orange and green to yellow. Both shields tied to ground
mike_i
Is your system NEMA0183? Do you have a NEMA 2000 backbone?
