Bravo I, II & III interchangeability question
Jersey Guy
I have a cracked Gimbal Housing Helmet on my Bravo III outdrive. My question is; can I use the Gimbal Housing of a Bravo I or II as a replacement?
Also, are other parts of the Bravo drives interchangeable between the 3 models?
achris
More fish than mountain goat
What is the serial number of your transom assembly?
There were 3 different bell housings used, some are interchangeable, some are not.
The only things that is different between a Bravo I, II and III is the gear housing. The drive shaft housing and transom assembly, within the same serial number group, are the same. That's why I keep asking for your serial number. Without it, can't give you any answers.
Chris..........
Jersey Guy
Getting the serial number off the outdrive will take a few days since I don’t have the drive and it is heavily painted.
However, I do have the flame arrestor cover which is badly worn which has the transom serial 0L863458 ?? (Not sure of last #)
I know the engine number is 0L682755 7.4 MPI L29
Question for you Marine detectives, can you get the outdrive number if you know the transom and/or the engine number?
See pic for a clue.
Ayuh,...... Within a given serial number range, the only differences are the Lower Units,.....
alldodge
From your previous post your needing the bell housing (part of the transom assembly), and yes most any can be used with one caveat. On top of the face or the housing look for slots on the top. The slots are there so the U bolts do not come in contact when fully raised. You can use the one without the slots but then need to limit the trim cylinders
Get on after 1989 and all should be good
View attachment 1988 and 89 Bravo transom Bul 89-12.pdf
muc
This is what your Crownline came with 5/20/2000
ENG: 0L682755 4542067N1 MERCRUISER 7.4L BRAVO MPI
DRV: 0L767584 5441600LS MERCRUISER BRAVO 3 2.00:1
TRN: 0L869458 6211001N1 MERCRUISER BRAVO TRANSOM
Jersey Guy
Thank you very much Muc.
I will certainly hold on to this information.
