Chuckd91
Thread starter- Joined
- Jul 1, 2018
- 36
im almost finished with a full rebuild/repower of my excel 20sl and cant get raw water into the cooling system from the outdrive. The engine is a 4.3 mercruiser setup with an alpha one gen 2 outdrive. Ive removed the engine and outdrive multiple times to fix issues along the way and cant seem to fix this one! The system has no restrictions from the copper tube in the foot to the thermostat housing and to the block. It was flow tested with water. The impeller in the foot is new and has been removed and checked multiple times. The pump impeller and cover is slid down the drove shaft as the shaft is turned clockwise. There seemed to be corrosion around the sealing area under the pump base plate at the thin aluminum rib the seperates the water inlet from the exhaust and was sealed up to be sure that want the issue. The copper tube and all o rings from the pump to the upper section of the outdrive seem to be fine and the o rings are new. The intake screen and passage to the pump and clear. Ive tried submerging the lower unit in a large comtainer and the water hose with muffs with no water coming in still. I need to do the break in on the engine i built and the overheating is not good! Lol
im not one to throw parts at something but im on the verge of finding another lower unit. Any ideas?
