Reuse or replace?
harringtondav
I'm ready to replace my oil seal-grooved gear yoke and seal. I just noticed this grooving in my coupler yoke gimbal bearing surface. Most of the surface is OK. I'm not afraid to dig into my pocket to replace a potentially troublesome part, but I'm on the fence with this one.
Thoughts please.
alldodge
Wait a minute, with the O rings isn't that the gimbal bearing side?
harringtondav
Yes. This is my coupler shaft. The grooves are the gimbal bearing diameter. The gear yoke is also being replaced. Typo error. Sorry.
harringtondav
You have checked the condition of the gimbal bearing. Right.
Yes. It's fine. Replaced last spring. Alignment is also good. I've never had a frozen gimbal bearing. I can't ID a reason for those grooves.
DouglasW
Are those grooves new? I don't know how long you have owned the boat. Is it possible those grooves were made in the past when the bearing failed with a prior owner? I reviewed the photos I took of mine when I removed the drive it last year. Some small grooves but not as deep. My gimbal bearing seemed to be ok.
harringtondav
I don't know. It's my original 23 yr old coupler yoke shaft. I once had a noisy gimbal bearing that I failed by a screw up I won't go into, but it wasn't frozen. I pull the drive regularly for inspection, but I normally don't pay much attention to this area. The grooves may be old.
achris
More fish than mountain goat
Pull the O rings off, run some fine wet'n'dry over it, clean it and put new O rings on... You'll be fine.
