crazy charlie
- May 22, 2003
- 5,683
I assume when using the flush adapter at the cowl the block gets flushed as well as the lower.I questioned if I should get another adapter and flush where the adapter unscrews from???
Don't know about Yammie, but the flush port on the Evinrude does the entire motor as long as you supply the required 30-40 PSI at the flush port to push the Stats open..
