Applying bellows adhesive when it's cold
littleape
I'm doing bellows/bearing on my alpha 1 and it's getting cold up here, around 50F, I see the bellows adhesive says to use when it's 68F or higher, it won't be that warm for the next 6 months. Any issues using it when it's colder?
Thanks
achris
More fish than mountain goat
You're almost 20 degrees lower than the minimum recommended temperature. That low and it won't set off... Wait until it's as warm as the instruction say.
shine a halogen shop light on the outdrive, it will warm it up
littleape
Yeah I was thinking of using a heatgun or a portable electric heater to warm up the area. How long do you think I would need to keep it heated for it to cure?
A heat gun is a fine line between not hot enough and the paint is melting. Would probably take about 30 minutes with a heat gun vs 5 minutes with a 500 watt halogen shop light
littleape
Think I'll just aim my portable electric heater at the area to get it warm, have the adhesive go non-tacky on the bellows indoors and then install it and keep it warm for a white longer.
achris
You need to apply the adhesive to BOTH surfaces....
