1968 Starflite Queries
andrew j cox
hey guys, i have a 68 starflite 85 hp its going onto my 68 15foot boat, can you get power tilt for these or trim n tilt?
I have heard you can convert ignition to car system anyone have the gossip on these? I love the engine such anold classic id just like to make it run good , im amputee couldnt manually lift engine.
F_R
There has been lots of discussion about converting them to automotive coil ignition. I'm still waiting for a report that it was truly successful / reliable. In theory, it should work, but the dwell is wrong and those motors had a lousy distributor, which you would still have to use.
jimmbo
A 1968 85 Starflight would have a CD system with distributor under the flywheel
F_R
Agreed, it is CD, with breaker points. The points is what tempts people to try to do away with the CD amplifier and use a car coil.
Post # 1 asks about power tilt.-----Post #5 appears to say that it already has power tilt.
oldboat1
Depending on your capabilities, if the power tilt works you could adjust the trim manually. Tilt it up, set the trim/thrust rod, then tilt back down.
jimmbo
With those engines, your prop choices are pretty pathetic. Very small diameter, for the HP(actually smaller dia than the 33/40 hp). A 23:20 gear ratio results in very low pitch props.
andrew j cox
I hadnt recieved motor when post one went up, i got it sight unseen
andrew j cox
As the tilt is a prestolite set up, a 82 suzuki has prestolite trim tilt same rams, why cant i fit the second ram and change pump over to chrysler set up which have trim tilt and re plumb it?
jimmbo
If you can make it fit, and not compromise the integrity of the transom/swivel bracket, or the transom securing system... That generation of engine was not engineered in any way to have a power trim system. OMC didn't make provision for Power Trim until 1973. Fortunately 1968 was the last year of production for your engines design, OMC abandoned it in 69 for a much more modern V4.
Specs for your 68:
89.5 cubic inches
85hp @5000 rpm
WOT range 4500 - 5500 rpm
Gear Ratio 23:20
Parts for it are getting harder to find and expensive. Carb gaskets are very hard to find. Inlet needle and seat are about $75 ea., there are 4 of them in that carb.
The 68 model 85 only has the one float valve !!------Not the same as the 68 model 100 HP carburetor !
Roberthill
I converted one years ago don't remember what year but it was a 75 or 85 hp Evinrude. Used a Voltswagen coil , set points at .019 , wired condenser out side of points location also had to change and use different spark plug J6 I think . Motor did not run as good using power pack but it was good enough .
jimmbo
Damn. That’s correct:watermelon:. Thank you racer for catching it
My mind was focused/distracted on how the 68 85hp made its 85hp @ 5000 rpm, yet our 1965 90hp made its 90 hp @ 4500, 500 rpm less. Both were 89.5 displacement. The 90, like the later 100 did have the 4 bbl.
The 64 / 65 model 90 hp both used the 4 barrel carburetor.-------Displacement might be the same as the 68 model 85 HP motor, but the block / crankshaft was totally different !
jimmbo
I never said they were the same block, just displacement, bore and stroke were identical, carb was different and reeds were arranged differently. But I found/find it odd that the 90 produced 5 more HP at 500 fewer rpm. Maybe the extra carb flow allowed a denser charge to get to thru the induction system. Too bad I can't get the porting specs to see what differences there were between the two
jimmbo
So they totally sealed the crackcase for each cylinder, equalizing the volume. I do recall seeing the crank with the filler blocks in an illustration in the 1964 90hp owners manual, but in the 65 manual it showed the correct crank. I assumed it was a revision on the production line between the years. Never took a 64 apart, took my dads 65 apart a few times
