Stern Ladder that Fits
legalfee
I have a 1995 Sylvan 824 SE and the rear toon extends about 10-12 inches past the stern decking. Does anyone know of a ladder that will fit with this scenario?
they make custom ladders every day.
had to make ladders for a buddy's 'toon
Your local fabricator specializing in aluminum and stainless
Cat nip
Post some pictures of your toon so we can get a visual. It will help to come up with some ideas .
alldodge
If you post a pic, might be able to find something, :noidea: but would need to know what your looking for
legalfee
I'll get pictures this weekend. I'd like a folding ladder.
legalfee
I measured and it's 8 inches from the edge of the deck to the end of the pontoon. The ladder I ordered only the front bolt holes reached the deck.
ahicks
So, time to get creative!
What would happen if you went to HD, Lowes, or your favorite hardware store and bought a length of heavy alum. angle (say 1/4"x2"?), and use that to fashion a couple of brackets?
There's a very sturdy looking stern eye that's just screaming to use it to hold the back of the top section level with the deck. From there it could also be used to support hold the section leading down to the water out away from the boat.
The rear most M bracket that supports the deck could have a couple pieces neatly bolted to it to help you out as well.
Think it through, do a neat job, and it should look fine when done.
Oh, and one of those 4-6" angle grinders cut through alum. like it's butter. If you don't already have one, a job like this could cover the 20 bucks or so they cost at Harbor Freight pretty easily....
alldodge
Agree, you can make some brackets
Found this one at Aqua Stairs
I like this one, just search pontoon ladder, about $250
legalfee
I like the bottom one too. I'll see if I can find it.
ahicks
While shopping, suggest you shop/check out the shape and size of the steps you'll be climbing up on. These old feet appreciate a little extra step width. 1" steps don't cut it for me any more.....
