The_Dude_Abides
Thread starter- Joined
- Jul 24, 2017
- 14
Ok, so this is a 2006 Mercruiser 3.0L TKS with an Alpha 1 Gen 2 outdrive.
So I finally found where water was leaking into my bilge. There is a hole in a cable (further down) that is leaking water into my bilge (i.e., the cable is filled with water - it leaks because it looks like the cable was resting on the exhaust and partially melted through leaving a pinhole - nothing appears to be leaking from the connection to the hull). The cable connection through the hull is circled in red and the cable joins a wire bundle that looks like it goes to the helm. I need help identifying it and any suggestions for why it is filled with water (I don't think it should be!). It leaks more in gear and moving and slowly stops leaking when put in neutral. My best guess from my internet sleuthing and my review my mercruiser service manual is that its the speedometer cable.
Any help is appreciated
Thanks Justin
Thanks Justin
