jamesdgreen2016
- Aug 26, 2016
- 80
Hello!
I have a brand new 20 foot bowrider with a Mercruiser 6cyl 4.5l 200hp engine in it. The prop I have is a 4 blade 19" that the tech in the shop I bought the boat at says is good for my boat. It was a prop I bought before the boat. The prop that came with the boat, which is not currently attached to it, is a 3 blade 19". Now, when I read the manual for the engine I have it says the 250HP 6cyl merc engine is to be targeting 5200RPM at WOT and the 200hp 6cyl variant which I have is to be targeted at 4800RPM at WOT. With the 4 blade 19" prop I have (listed below) the RPMs at WOT with the boat are about 5200 with two people on the boat. Im assuming because the other prop that came with it is also 19" it would be around the same RPM at WOT? I called the store that sold me the boat to speak to one of their techs and ask if the fact that its hitting 5200RPM at WOT and the manual suggests a target of 4800RPM at WOT is going to be a problem. He said that as long as I wasnt running it at WOT for long periods at a time, like hours, it wouldnt be. Do you guys agree? Or what do you think I do here? [h=1]Turning Point Hustler #21501930 Aluminum Boat Propeller
http://ww2.boatpropellers.iboats.co...501930_Propeller/765/35668/?cart_id=412279958[/h]
