1958 Johnson Super Sea Horse 35 hp engine question
salju6
Hi Everyone:
Brand new to this forum. I purchased a beauty of a boat from the original owner:
1958 Thompson Sea Skiff 2 mated with a 58 Johnson Super Sea Horse 35 hp engine.
The boat is in fantastic shape. The gentleman took excellent care of this craft. He winterized the engine and kept it inside during winters and it shows.
THe engine has not been run since 2015. It was winterized and has not been cranked since. I live in Maine and want to get it in the water this month(fresh water lakes- it came from Minnesota so it has only seen fresh water). As I dont have an engine log from the gentleman, what should I do before I hit the starter?
Caveats: I know nothing about engines especially these except the oil to gas ratio is 25:1 , use fresh gas, they are of the era where environmentally friendly means you have an ashtray in your boat instead of throwing your butts over the side and they are gas hogs.
Questions off the top of my head:
1) What do I do with the gas that is left in the tank?
2) Gas stabilizer for what reason?
3) Pull the plugs before trying to start and do I clean them with a wire brush or just replace for new?
4) What oil should I use/what octane gas for this 60 yr old engine?
5) What IS the gas consumption like on this engine in a 600 lbs boat?
6) WHat should I NOT do when running an engine this old? I am only using it weekends and it will not be docked but launched and garaged beteen uses/
7) Any tips for maintaining during the summer when it is not in use?
I know it is a long list but I want this boat to remain in good shape- it is only 4 years younger than myself!
Thank you
Justin Salerno
F_R
Since you do not know the service history of the motor, you should expect having to do most of the following:
At least check the ignition system.
Check or replace rubber hoses. If it was properly prepared for storage, the carburetor may be ok
Replace the water pump impeller for sure.
As for your questions:
1: Do you mean it was in there for 3 years? Take it to a local hazardous waste disposal facility.
2. It prevents deterioration of the gas for up to a year.
3. Part of ignition check. Depends on condition when you look at them
4. Any reputable brand of outboard motor oil that is certified TC-W3 and 87 octane gasoline. 24:1 mix. Lots of debate on the ethanol question. Personally, I don't worry about it.
5. About 4 gallons per hour at full throttle.
6. Don't sink the boat. Seriously, they are tough motors if not abused.
7. Keep it lubricated. Prepare it for storage when winter comes. That includes oil change in lower unit.
salju6
I was already thinking about replacing the tubing.
I was also thinking about getting a new pair of spark plugs but I don't know the exact type because I don't have a owners manual could you help out with that?
I am told it to these old seahorses put out A lot of smoke as it certainly preadmissions pretty green. I've also been told that you got to start worrying if it stop smoking is that right?
Thanks so much for the come back I'm sure I'll have more questions I hope your patient
F_R
J4C spark plugs. Getting hard to find, so lots of people are settling for J6C
Yeah, they smoke. And before you ask, they cause an oil sheen on the water too. And they make a cruddy mess if you run it in a barrel. All completely normal back in "The Day".
I had one of those that I bought brand new in 1958. Ran the daylights out of it for several years, skiing, etc., in salt water. Salt eventually won out.
oldboat1
Good plug would be Champion J6C, gapped to .030. If it's tuned right and used fairly regularly, there shouldn't be a whole lot of smoke -- actually can run pretty clean. Keep it at 24:1. Some believe synthetic 2-cycle burns a little cleaner.
There is a removable plate on top of the flywheel, which allows you to get a peak at the coils. If the housings are cracked, they need to be replaced. Point gap is .020 and need to be squeaky clean (can do that through the hole on top).
I would check eBay for an oem parts manual (more easily available) -- service manual if you can find it. For an aftermarket manual -- better than nothing -- I like the Intertec Old Outboard manual.
salju6
F R and oldboat1
I am in your debt. Thanks for your advice and reassurance.
Like myself, the days of going full throttle nonstop are best left back in younger days for the old Sea Horse.
Slow and steady wins the race.
Will keep you informed.
JJBoatr
Sounds like you acquired a great little run about with a darn near bullet proof vintage outboard.
One thing I didn’t see mentioned was inspecting the condition of your fuel tank and lines. If the motor is all original it should have a pressurized fuel tank. Identification of this style tank is easy, if you have 2 lines running from the tank to the motor then that’s what you have. A single line with a primer bulb means that it has been converted to a slightly more modern vacuum fuel pump, which wouldn’t be a bad thing.
a pressure tank will have a plunger button that pressurized the tank for starting, with the cap tight press that button until you feel strong resistance then spray soapy water around the gasket surface and check for bubbles. If there are any leaks whatsoever they need to be repaired, gasket kits are still available for the old tanks.
F_R
With all due respect, the 1958 Johnson Super Sea Horse and Evinrude Lark did not have pressure tanks. They and the V4-50 were the first Johnsons and Evinrudes to come from the factory with fuel pumps. But fuel pumps were an accessory item prior to that.
JJBoatr
I was not aware they used vacuum fuel pumps prior to 1960...thanks much for correcting me on that, definitely don’t want to give bad info. Learn something everyday. Good news for the OP.
i would edit my previous post but for some reason I can’t.
jimmbo
In 58 OMC did have the two completely different 35hp models, so there is some confusion out there, 60 yrs later
Old design was Sea Horse and Bigtwin
New Design, as you mentioned, Super Sea Horse and Lark
