toneybrown
Thread starter- Joined
- Jul 1, 2013
- 104
Hey guys, back again trying to figure out an issue. My power steering has a leak and I'm not sure if I am looking in all the right places for it. I filled it up, and while the engine was running had my wife turn the wheel all the way right and left over and over while I looked for a leak.
I checked both hoses leaving the pump, both dry and no oil under them. I checked the connections at the actuator and the actuator. Again no visible leaks, no oil under them. Next checked the hoses going into the oil cooler. No wet or leaking hoses and the oil cooler was clean and free of oil.
Left the pump full of oil and gave up. Went out about a week later and notice oil in the bilge again and pump is almost out of fluid. The only place I can see any wet oily spots are at the bottom of the pump were a bolt connects its to it on the back side.
So, can a pump just leak out of the bottom? If so is it just a simple pump replacement? I am 99% sure all hoses and connections are not leaking. Unless there are more hoses I just can't see.
