Volvo Penta 7.4Gi sputtering
GeoH
hi all,
I have a 2000 cobalt 246 with Volvo Penta 7.4 Gi. Ran fine two weeks ago. Started out for boat ride last night...started fine, ideled fine, ran fine for about 1/4 mile then began sputtering. Brought it back in let it sit a few minutes and then tried again...same result. Ran fine for a little bit then started cutting out.
would this be spark plug/distributor/rotary related or would this be fuel filter fuel pump related....or something else entirely
thanks
geo
Check for spark
check for fuel pressure
Check for water in the fuel
alldodge
What happens when its sputtering if you give or more or less throttle?
GeoH
Sputters worse with more throttle once it starts sputtering
alldodge
Sounds like its not getting enough fuel. I would check fuel pump pressure. You have two pumps and low and a high pressure. The low pressure keeps the tank full and the high pressure supplies to injectors
Low pressure above the fuel filter
High pressure inside a tank
https://www.marinepartseurope.com/en/volvo-penta-explodedview-7797250-23-10795.aspx
Don't know which Gi you have to determine fuel pressuers
GeoH
Emptied the fuel filter filled it with gas and put it back on and it ran fine again
thanks
