Force to Chrysler Swap
andrew j cox
I have a Force 150 powerhead on the way, I’m keen to know if the 150 will directly bolt onto a Chrysler 4 cyl leg and the exaust tube, and is the one piece Force gearbox compatible too
jerryjerry05
Any idea the years??
If the adaptor/spacer plate is on the block, it will fit the mid section.
The drive shaft should fit.
The shift linkage might not work if the block is 93/4 they used Mercury linkage.
jerryjerry05
That should fit.
The gear ratio will probably be different but with a prop change it should be ok.
