Maybe check your anti-siphon valve and the inlet screen on the pickup tube from the tank. You could be getting gas, just not enough, and something is restricting the line.
Also if you left your tank half empty over the winter you could have condensation that formed and you now have water in your tank. Maybe collect some of the gas from the fuel filter and let it sit in a jar a bit and see if it has any water in it.
Shop said the carb wasnt properly done and that is the problem. The tech could keep it running if he constantly gased the throttle. WTF? Paid 200 for professional job.
How long was he able to keep it running? Did he get the carb straightened out?
Do you mean above "idle" throttle (but at steady-state) or he had to keep pumping it to keep it running? If he had to keep it cracked above idle then maybe the idle speed adjuster screw needs to be turned in a bit to open the plates some or the mixture screw is grossly out of adjustment. If you pulled the carb and took it somewhere to have it replaced, these are two adjustments that will NEED to be addressed after install to run it. If he put it back on the boat and called it good, he should have set it.
If he had to keep pumping it, then it sounds like the idle circuit is fully plugged and it's running off the accelerator pump. Severely retarded timing can also require the throttle to be higher or even the throttle to be pumped, but you'd hear the exhaust very loudly and probably get steam from the still-burning fuel exiting the exhaust valves and hitting your riser water. It can be hard to get the timing right to run it when you've lost your reference but you can tell if you're too far advanced when the starter gets slow at the compression stroke of the firing cylinder (it pretty much stops the engine briefly). Back it off about ten degrees from there and you should be ok. Time it with a light ASAP when you get it running enough to do so (but you probably know that).
It should be warm enough as well to run without the choke. I wired mine open when I was having issues so that I could rule it out.
As the owner of a 2003 Bayliner with the same setup, I'm anxiously waiting for an update. I hope it's worked out for you. I'm getting ready to do a carb rebuild, but am a little intimidated. First time rebuilding a carb, but there's so much on YouTube that I hope I can just follow along.
Hope you get your issues sorted, and come back to finish the story!
How many times did you pump it vs. what you used to do?
If it sits the carb bowl can dry out. Most likely the first five pumps there isn't much if any fuel in the carb, when you crank it then the fuel bowl gets refilled from fuel pump.
Note to self.....drain ALL gas before winterizing! At least I have freshly tuned motor now.![]()
