TBarCYa
Thread starter- Joined
- Apr 13, 2005
- 781
Since you're probably the same people that would reply if I started a new thread...
I got the engine running but need it to idle on it's own so I can set the timing. What I noticed is that there's fuel dripping down the outside of the carb that I believe is coming from the inside of the flame arrestor. Having learned the hard way, I don't want to start it without the fa but I suspect that I need to rebuild the carb. Does this sound like the right direction or should I focus on the timing first? She sounds good and will run if I give it throttle but won't stay running on it's own.
