1968 johnson fd22m not starting
steinbro
Recapping i have timed and set. Have take plugs out and both have a good multiple sparks per pull.
steinbro
I dont know how to make it jump farther than the spark plug allows?
Crosbyman
steinbro
Ok so got spark first time at 1/4" on say top plug booth but could not seem to get it again. Than did bottom and could not get a spark to jump at all it seems
Crosbyman
did you ever measure coil secondary resistance from plug booth spring to engine block.... set needle meter to 1Kohms or use auto-ranging digital meter
you MUST see 4-7 Kohms if not ..................wiggle the wires and check for sudden readings to show up
plug booth pin prick may be corroded or High voltage coil pin to wire connection may be corroded requiring disassembly and reconnections after snipping off 3/8 inches
better yet install new solid core wires (no carbon wires)
clear one issue at a time....
steinbro
This is top plug booth reading
steinbro
This is bottom plug booth reading.
Crosbyman
you must get the bottom booth plug to read the same or close to same like the top one. Meter indicates no direct physical continuity between the engine block "ground " reference and the booth clip pin
that said you can try to poke the plug wire just behind the booth with your probe tip sharpenned up to a needle point
redo ohms test by touching the wire inner conductor behind the booth... if you get a reading (6 kohms) and nothing in the booth clip it is likely corroded inside the booth where the spring clip punctures the plug wire.
if so just redo the connection by removing the spring clip (pull the booth further back on the wire while extracting the spring forward cut-off 3/8 to 1/2 inch of wire, polish up the pin prick reinstall slide the spring clip in the booth using a spark plug for leverage and slide the booth forward back over th clip (apply grease if need be)
retest for continuity
should you not see 6,000ohms or so when punching the wire behind the booth you have
1- a bad wire
2- a bad connection at the High voltage coil pin output. (corrosion)
3- a bad coil secondary winding
NOT a big job but you will need to test the coil's pin and if OPEN coil si dead as par #3
if 6000ohms coil is good and wire is tested bad... replace the wire with a new section of solid core plug wire (no carbon wires !!!) copper or metallic wire is available at motorbike shops usually get the 7mm wire size
I would rebuild both plug wires while you are in there you must pull the mag plate off the power head to work properly
btw if you have not read the bible you should
http://162.144.28.33/
Crosbyman
hello... steinbro.... any updates have you given up ?? it is nice to see oldies running again ;)
steinbro
Update is i could not get the coil and plug or even just the wire to read the 6000 ohm or so i have ordered new coils, booths, plug wires that should arrive tomorrow and than i can get back to getting that set up. I am determined to get this motor running.
The " universal magneto " on your motor was used for about 40 years.----It is a very good unit , simple and reliable.------But for a novice the concepts of magnetic fields and electricity can be intimidating.-----You can not see them but they are there.--Google ----universal magneto------Perhaps that will help you understand this unit.
steinbro
Update is new coils new plugs and booths. I have again set points and timing. Also have a readout of plugs of 4550 ohms on both top and bottom(that issue seems corrected. Now out of testing i started it up and it idled for say 1 to 2 seconds than it high revved and than shut down. any thoughts on next step? Would be the fuel or carb or ??
Crosbyman
if you are confident about the ignition (fire) the next step is fuel delivery ... from the tank to spark plug
assuming no obstructions in the carb (for now) .... try pumping the bulb when it starts just in case the fuel pump is bad
Since it only runs1-2 sec I would tend to suspect carb issues because the bowl should have enough gas to run more than 2 sec.
did you ever open up your low speed drip chamber and clean out those 3 small drip holes ?? and blow out all fuel and vent channels on the carb with high pressure air ?
one reason for not sucking in the fuel in the carb is air being sucked in from bad cranks seals. put yor hand in front of the carb face while a friend starts or pull the cord.....do you feel the engine sucking in it air enough to pull fuel from the carb (venturi effect)
...keep at it one avenue at a time :cold:
I am not sure why you are " focused " on these ohm readings ?----Does spark jump a gap of 1/4" or more, yes or no.----If it does , then you have a magneto that is ready to perform for you.----New plug wires should be a metal core wire 7 mm size.
Crosbyman
it is true that sparks can jump across air and corrosion points to reach the plug's air gap but fundamentally the goal is to reach the plugs with the least resistance along the way to maximize the voltage drop (spark) across the " highest resistance point AKA "the gap " as per ohms law.
In telephony (plain old telephone service AKA POTS) local copper pairs were prone to green oxidation causing electrical unbalances and "noisy pairs"
Rather than trying to locate each point of corrosion telephone techs would simply zap the cable pair with DC 130 v ... or more to burn out the oxydation and literally weld the wires remotely from the central office.
No need for this on 2 feet of wire... good electrical joints makes for happy motoring :joyous:
but I am sure you knew this ;)
steinbro
So i am done with carb apart cleaned throughout with new gakets and such. All put together. went to start and it does seem to have a better pull with idle sounds better and lasted i say 6 to 8 seconds than suddenly like a choke died. Tried to start again and doesnt want to hang on too much. It seems to be improving but not running. I have slow speed adjusted to 1 round turn out of full set in.
valvebounce
one and a half full turns out is the starting point.Have you pumped the bulb up solid?Did you clear out the jets with carb cleaner,and check the cut off pin controlled by the float?If the cut off pin sticks you will not get enough fuel into the carb bowl.
Crosbyman
and you did install the fat base gasket below the high speed post
and you did clean the low speed chamber and blew all channels / cavities with pressurized air
and you did move up your throttle beyond "start" because "start" is some times not good enough
and you did try pumping the fuel pump to keep it going in case the fuel pump is bad
and you tried to keep it alive longer by timely spraying some fuel in the carb
and you did a blow test on the fuel pump (in to out but no air out to in)
and you did open up the LS needle as suggested or... a bit more to allow more fuel to the idle chamber
did you... ?? please confirm all above checks
