trihull design
nightvision
Hi all,<br />I'm in the process of restoring a trihull fiberglass 15 footer. Being new to boating, I'm curious to know how stable is a trihull in small lakes. Our use for this boat will be mainly for fishing. I can see my son and I walking around the bow area and just walking around in the boat. How would it ride in choppy waters. thanks for any comments.<br /><br />Thanks.
Re: trihull design
As you can imagine,<br />A Tri-hull Is Extremely Stabil.......<br />But, They tend to Pound in the Chop......
MooseHootie
Re: trihull design
I have a 69 tri-hull it runs 32 with a 85 on it. It bounces in waves up to two feet, I have jumped waves 3 feet by accident and it came 5 feet out of the water. You can turn it hard in any direction at full throttle and it just slides on the water, dont lean at all. Very fun boat but selling it this year beacause I bought a lot bigger boat.
MooseHootie
Re: trihull design
mulv80
Re: trihull design
My father had a 1974 18ft Thunderbird Tri-hull with a 90hp Evinrude. The boat would jump up on plane almost in an instant and corner like it was on rails. We used it on the Delaware Bay and never had a problem with chop. The boat was extremely stable. I was never a fan of Trihulls but this boat changed my perception. Can't imagine why they don't make them anymore?
JasonJ
Re: trihull design
The pounding is a generalization that is untrue of all tri-hulls. The individual differences from manufacturer to manufacturer varies widely. Some tri-hulls had shallow deadrise at the transom, and were little more than flat hulls with exagerated chines. Others had very deep deadrise, and the outer sponsons barely even touched the water when on plane, giving a ride very similar to a standard deep V hull. My tri-hull for example has almost 23 degrees deadrise at the transom, and that continues to the bow, where it gets even steeper. When on plane, I rarely catch air, and it cruises through chop like it isn't there. It leans quite hard in sharp turns, and like a deep V hull, does not jump on plane immediatly but takes a few seconds and 2/3rds throttle. In effect, its like a deep V hull with a lot more room in the bow. At low speeds and at rest, it is very stable, I can walk all over the front and there is no dramatic tipping or "tenderness". Low speeds and rest position is the only time the outer sponsons are touching the water. in effect my particular hull design has the best of both worlds. The only current boat I can think of with a similar hull design is the Hurricane Fundeck, and it got great revues when tested. If person was actually looking for a tri-hull, they should look for a lot of deadrise. the other consequence is they can be heavier as well, but the stability makes it worth it.
POINTER94
Re: trihull design
Hey its a boat---they are all good!!! ;) <br /><br />A 15ft boat limits you to smaller lakes to start with, but the above posts make some very good points. They are more stable and they typically give up a little in rough water capability.
hayhauler
Re: trihull design
mulv80 wrote, "Can't imagine why they don't make them anymore."<br /><br />I was unaware that they weren't making tri-hulls anymore. I would think someone still would.<br /><br />I just sold a tri-hull, because I'd gotten a bigger boat. I'm still not sure I did the right thing. The tri-hull was a great boat that served my family for many years.
thehermit
Re: trihull design
Amen Pointer! Time on the water in any vessel is a good thing.
kenoshabrew
Re: trihull design
I have had my 1969 Chrysler on Lake Michigan plenty of times. I've had it in 1-3 foot waves with no problem. I've traveled about 45 miles following the shoreline on Lake Michigan and was comfortable.
Usually I'm on a chain of interconnected lakes in the area call the Chain O'Lakes in Illinois (Fox Waterway Agency). The boat is very stable. You seem to loose some top speed with a tri-hull. One thing I'd like to point out is my brother has a deep V and rides much more rough then my tri-hull.
Perfect for fishing as the boat doesn't lean like a v-hull when walking around.
ParallaxBill
Re: trihull design
My old Glassmaster was a modified tri-hull design but as you can see in the pictures the main hull forward has quite a deep V design. The side sponsons are well out of the water when trimmed for a nice ride at speed on anything including moderate chop. In heavy wind/chop I usually stay home anyhow but it will get rougher riding in heavy chop.
I offer up these pics just to show this rather old but conventional modified tri-hull for the time it was built late 60's thru the 70's.
I fish out of mine and nothing seems to be any more stable than a tri-hull when not on plane for moving around the boat.
David B.
Re: trihull design
I had a 15' merrimack trihaul (1978?)for about ten years on the chesapeake. when it was rough out you would take a good pounding if you rode to fast, you would usually get a little wet to. but I still miss cruising around in it when it was calm out, it was really speedy and smooth when the waves were flat. I always thought it would be perfect on a lake
redfury
Re: trihull design
Project skanky beast really went through a transformation..wow!
I am currently rebuilding a glastron trihull. Mine is 17 ft, mainly because I wanted the space, and my wife really likes the seats back by the splashwell.
Looking at the various trihulls out there, I really like the looks of mine, and I've seen some others that really look nice too. It's those old trihulls that had the stubby noses on them that really take the pounding because they just chop up the waves, not disperse and cut through them. Having the sponsons will help with sitting in the water and moving about the boat for stability.
One thing I notice is some of these newer boats out there coming up on plane....the nose is so far in the air!
I like the idea that I'll be driving close to on plane when I'm at partial throttle.
jaxnjil
Re: trihull design
my wife and i just bought a used tri hull and are very happy with it. we find not to be near as tippy as my sons vee hull.
reelfishin
Re: trihull design
A trihull is probably one of the most stable hull designs, the only thing that would be better would be flat hull. A twin hull or catamaran is stable, but they can have cornering issues.
Like above, there are lots of different designs, and all act differently on the water. I have two trihulls, a Starcraft Capri 17 and a Duo Gypsy, both ride great, the Duo is a bit smoother in chop due to the deeper V design overall.
I have a buddy that has a Glastron 17' trihull and it's the roughest boat I've ever been in. In anything but the smoothest water, it pounds pretty hard. That's one design that I wouldn't want, I haven't figured out why that one is so rough, it's got a pretty deep V in the center.
My Duo is a pretty shallow boat up front, but the V deepens as it goes back, and the outer hulls are pretty minor and start farther back. It's rock solid at rest while fishing. It handles much like my old flat bottom skiff only with better handling on turns.
kmurray802
Re: trihull design
I recently purchased a 16' Scout C.C.The hull design on that boat looks like it may have been influenced by the old tri-hull design.It looks almost like a cat with a V in the middle.Scout calls it "air-assist".What ever it is,it works!
The ride on that boat is incredible for a 16 footer.Also very stable.I'm surprised more of the manufactures are not using similar designs.
clemsonfor
Re: trihull design
Your scout is a copy of a whaler hull, look at a boston whaler a very stable boat that looks more like a trihull in all sizes from the 13' to the 20+ feet althoug more v like in the bigger boats. Whalers hull remains virtually unchanged for 20 or more years, Carolina Skiff has tried to copy it and scout i think with there new boats (the DLX) series i think in the last couple of years.
-Nate
barbwire44
Re: trihull design
Ive got a 15' sea sprite sea mist tri-hull with a 70 hp mercury on it and I'll tell ya I think that little boat planes out quicker than my buddies air nautique!!! And they do just seem to slide through the turns, pretty fun little boat would love to put a little bigger engine on it, the poor little 70 maxes out at about 25 mph. But has no sweat yankin a #200 skier out of the water
jddenham
Re: trihull design
I am going to start on this tri-hull shortly. I just got it on a trailer.
Any opinions on the potential characteristics of the hull?
kmurray802
Re: trihull design
-Nate
It very well may be copied from the whalers.I don't see a lot of whalers where I'm at in Florida,a few but not that many.(not sure why).Anyway,great design whomever came up with it.
