Needing some help with part numbers
stouchton
Folks - need a little help with finding an exploded drawing with part numbers for DP-SM transom shield, year is 2004.
Cannot find an exploded parts diagram, and have seen on several vendors sites where it states SX transom shield parts are not compatible with a duo-prop.
In particular, I want to replace the water hose, nipple o-ring, bellows, and upper unit to transom shield gasket. Just want to make sure I am ordering the right things.
I did find an exploded view of the upper unit on marinepartseurope, just cannot locate the transom shield. Figured the SX-M would probably be the same, but again no exploded view on transom shield.
Any clues greatly appreciated.
Scott
Thalasso
Yours should be the same as a SX-M
#DescriptionPartNo.QtyPrice/each (EUR)
1Housing 38171461 1 248,50
Pin
38525491 23,63
Fitting
38076881 17,00
4
Hose
38078901 67,25
5
Flange screw
38524542 4,26
6
Kit
35876511 17,88
7
Sealing
38525501 11,63
8
Stud
38525762 35,63
9
Stud
38525464 23,75
10
Plug
38519751 3,70
11
Retainer
38525551 2,88
12
Bearing
38525471 30,63
13
O-ring
38570871 7,73
14
Tube
38525641 8,26
15
Fitting
38521211 21,63
16
Block
38525591 334,13
17
O-ring
38521691 2,10
18
Stud
38521411 20,50
19
Washer
38521931 6,38
20
Nut
38520051 1,86
21
Sealing
38525481 32,63
22
Bearing
38538071 Out of production
replaced by next part number
Replaced by:
Bearing
217527121 173,50
22Bearing 217527121 173,50
23Arm 38523791 306,25
24Washer 38525541 5,71
25Plate 38525851 9,90
26Screw 1 Out of production
Obsolete part
27Nut 38520044 5,48
28Cap 38572381 184,38
29Flange screw 38571464 8,96
30Decal 38576521 10,49
31Bracket 38581921 265,50
32Hexagon screw 38521513 7,38
33Washer 3 Out of production
Obsolete part
34Anode
stouchton
Thanks for the help.
Thalasso - where did you find that exploded view?
Scott
stouchton
Also - MarinepartsEurope under maintenance parts for SX-M and DP-SM list 3 bellows?? Peaking up under my gimble housing I have only seen 2.
One looks like part number 22197130 and the other like 3850426. Both are ribbed/accordion. 3587641 appears to be non-accordion - where exactly does that go, or is it a substitute?
Scott
Thalasso
Scott
Volvo Penta Exploded view / schematic Transom Shield TSK SX-M ...
https://www.marinepartseurope.com/.../volvo-penta-explodedview-7746050-44-8973....
There is only two bellows. One is exhaust and the other is for your input shaft
The number
22197130 is the kit which has both bellows which is out of production
1Anode, aluminum 35864611 57,10
1Anode, zinc 38541301 36,50
1Magnesium anode, magnesium 38556101 66,20
2Anode, aluminum 38631931 34,20
2Zinc anode 38554111 43,40
2magnesium anode 38554121 57,10
3Anode 38578571 86,75
3Anode 38578581 157,25
4Zinc electrode 8733952 37,38
SX-MHP
4Anode 38634802 52,63
SX-MHP
5Transmission Oil Out of production
Fill level is determined by dipstick
USA
5Transmission Oil 11416793 Out of production
12x1 qt
5Transmission Oil 11416801 Out of production
4x1 gal
5Transmission Oil 11416811 Out of production
5 gal
Europe and other markets
5Transmission Oil 38094433 Out of production
1L
Replaced by:
Transmission oil224796503 24,40
5Transmission Oil 38094421 Out of production
5L
Replaced by:
Transmission oil224796481 108,80
5Transmission Oil 38094411 Out of production
20L
Replaced by:
Transmission oil224796471 384,40
6Bellows kit, u-joint 221971301 Out of production
Replaced by:
Bellows kit230757521 85,00
6
Hose clamp
222748871 7,00
7Bellows, exhaust 38504261 97,60
7Hose clamp 38526031 7,80
7Retainer 38526651 24,50
8Bellows 35876411 30,80
8Hose clamp 38526031 7,80
stouchton
OK.. found exploded views under TSK SX-M 1998 to 2005 on Marine Parts Europe but now I am a little more confused. It references an early version and a later version. How can one tell which version they have?
Seems water hoses are a different diameter between early and late. Would I be safe in assuming that since my outdrive is a 2004 it would be a later variant?
I am not near the outdrives to go look at the moment (boat is way far away at marina).
Thanks again.
Scott
the US site is volvopentastore.com.
stouchton
Decided to buy both size hoses and orings for the nipple - will return he wrong hoses and toss the spare orings into the collection!
New to Volvo Penta, but have spent about 25 years taking care of a pair of Merc 165's on a beautiful old Stamas Americana V26. So looking forward to pulling the Volvo's off and making sure all is OK. Boat is new to me, so it will get new boots, hoses, greasing and alignment checked.
On a slightly different note, does anyone have a good recommendation for a sealant to use on the boots? I caught in another thread to use waterproof grease on the nose of the upper unit to seal against the boot, but didn't see what folks are using to seal boot to gimble housing and transom plate.
Thanks again for all your help.
Scott
BRICH1260
Scott
I don't think any sealant is required on the transom plate end of the bellows. However I like to apply a very thin layer of triple guard grease on the grooved area to inhibit corrosion and facilitate the ease of getting the bellows over the grooved lip.
