85hp Mercury Trim Pump Nightmare
Derekc294
Sent him a message and email still no response. Anyone else have any leads? Next choice will be to swap it all out and start from scratch.
He might be out of town for work.-----Patience helps----First post on this was 2 months ago.
Did you look for ARCO aftermaket replacement? There may be one laying around. See my earlier post.
Derekc294
So I have the new trim motor attached and it came with a new solenoid. Only problem is I cant remember how it was all wired as it was so long ago. MERCURY MARINE 89-96158 is the solenoid with an Arco 6217 motor.
I guess I should have taken better pictures. What a nightmare!
Derekc294
[No message]
Some Merc PTT systems have only one solenoid. It will be used on the "Up" circuit. So blue from the motor wire goes on one large post. Red wire goes on the other large post. You still have the 3 wire plug wired, right? The blue wire from the female side of the plug, goes to the small terminal of the solenoid.
Derekc294
I have two large posts and two small. I was thinking one is a + side the other is - side but I don’t want to chance burning up everything.
Derekc294
What’s odd is nothing came with any type of wiring diagram and nothing is marked
Yes, one of the small terminals on the solenoid is to be grounded.
Was this different than how the original was wired?
Derekc294
That’s the problem I can’t remember. Probably from a concussion I sustained in an accident so my memory really is terrible at the moment.
Derekc294
Pushed the boat back in the garage. Getting a FOR SALE sign tomorrow and selling it as is. Done with this junk..... thanks for all the attempted to help. I’ve given up.
