- Mar 8, 2009
- 44,793
Trying to decide which sealant to use for below water line trim tab reinstall. Has a 1/2 hole going thru the transom which will have the feed tube to the pump. Removed the old and the sealant was still pliable. Held to the hull and tab hinge very well but felt like and looked like white rubber. Maybe it was 5200, have never had to take anything apart which I knew was put together with it before.
Would automatically use 5200 but I might need to take it apart again if the hinge gets cracked again
