3 vane or 6 vane impeller 1995 70hp
fishfeatures
Just changing out the impeller my '95 70hp I recently acquired and noticed that the impeller is 3 vane. Any motor I've had before around that size has the 6 vane impeller. Is there any difference ? i usually saw 3 vane in lower hp engines not in 70's.
jimmbo
Were both the old impeller, and the replacement 3 blades?
Fewer vanes to break and slightly less friction
Faztbullet
This impeller is a volume design and the 6 vane is a pressure...
Go with 6 vane.-----Install the waterpump kit with thermostat modification / changes while you are into it !!
fishfeatures
Thanks guys for that, ill order a 6 vane rebuild kit.
What are the thermostat mods you mentioned racerone?
Run to a competent shop / dealer and get the kit.----Includes thermostat parts and instructions.
